It’s a 48v system.
what about the advertised specs 100A continuous??so 30*48 (nominal) = 1440 Watt. Does it make any sense that each battery cannot handle more than 1500 Watt load??
It’s a 48v system.
I read somewhere the 30A is bogus and you can do 100A as confirmed by SS. I just wish someone can devise a scientific test of this to put everyone at ease.what about the advertised specs 100A continuous??
I ordered another inverter today for delivery tomorrow. I'm suspecting in my case it fails @ 40ish Amp which is not acceptable. Will confirm.I read somewhere the 30A is bogus and you can do 100A as confirmed by SS. I just wish someone can devise a scientific test of this to put everyone at ease.
I know many people don’t have access to such equipment but if someone has a current shunt of 50milliohm, 0.1ohm, you can put a cheapie 50Mhz scope and get the inrush profile of the inverter.I ordered another inverter today for delivery tomorrow. I'm suspecting in my case it fails @ 40ish Amp which is not acceptable. Will confirm.
Never mind. With the victron smart shunt, the burden voltage is 50mV @ 500A so you would need a good scope with at least 1mV input noise to measure 10A resolution. Most have 10mV accuracy so you would only get 100A resolution.
If it were a V8 car engine and a couple of the cylinders had low compression, it would run poorly, have less power and fuel economy. Same when a cell or 2 are not matched to the others. Voltage is a very good indicator of charge, it's just a VERY small change over a large percentage of charge with big knee's top and bottom.I want to know what the obsession is with watching cell voltages. We are working with lifepo4 and the natural variation with a 16S pack is well known. And voltage is not a indicator of soc with lifepo4
Hmmm I wonder?I'm curious. Have any of you that have had such a horrid time with your batteries and customer service, taken the time to leave a negative review on the SS website? All I see there are positive reviews for the batteries and I'd like to know if they're filtering the input.
Most of the people that know these batteries exist and bought them is because they read about them here or saw Will's videos.Incidentally, I would have to leave a positive review as the 4 Lifepower4 batteries I have perform flawlessly. I'm sure that a negative review from people that have had a less than stellar experience might better get their attention vs venting here, where only a few select people will ever read about your issues.
Notice the 30 Amp recommended next to it. Even top members like @FilterGuy have been asking what exactly does that means and they have gotten no response.what about the advertised specs 100A continuous??
agree, he needs more info from other members though to back the defective BMS claim. Coming soon, may be!BTW I liked the video that @Will Prowse released today. It was balanced and pretty much covered everything.
yeah, noticed thatNotice the 30 Amp recommended next to it. Even top members like @FilterGuy have been asking what exactly does that means and they have gotten no response.
Yep!If it were a V8 car engine and a couple of the cylinders had low compression, it would run poorly, have less power and fuel economy. Same when a cell or 2 are not matched to the others. Voltage is a very good indicator of charge, it's just a VERY small change over a large percentage of charge with big knee's top and bottom.
25 Ohm 100 Watt or you can use a 50 Ohm 50 WattCould someone tell me the correct size (if it matters) resistor for a 48V 100AH battery, so I can test them.
I saw a video from Will, but it was for a 12V 100AH battery (25W 30ohm).
Thanks.
Hey @robby, i've always wondered about using an external resistor when the battery already has one built in. If you cannot de-activate the internal pre-charge function, should any consideration be made for the combined value of using two together in the same circuit?25 Ohm 100 Watt or you can use a 50 Ohm 50 Watt
25 Ohm 100 Watt Link
Absolutely, you have the 2 resistors in series until the BMS bypasses its own resistor.Hey @robby, i've always wondered about using an external resistor when the battery already has one built in. If you cannot de-activate the internal pre-charge function, should any consideration be made for the combined value of using two together in the same circuit?
Are you sure this will work?Absolutely, you have the 2 resistors in series until the BMS bypasses its own resistor.
JBD BMS uses a 10 ohm resistor.
