My system is new and I'm in the process of optimizing the settings. I have some questions and am hoping I can get some advice on settings from you guys.
Question 1: Does the Sol-Ark low battery cut-off at 20% make sense given that each battery has a BMS protecting it from over-draining the battery? Or to put in a different way, Should I set the Sol-Ark's low battery cut-off to 0% or 1%?.
Question 2: Given that there are 6 BMSs in the batteries, are the Sol-Ark battery settings critical? Should I 'widen' the battery charge (and possibly discharge) parameter so that the Sol-Ark doesn't try to limit charge and discharge currents, letting the batteries BMSs control the charge and discharge cycle?
Given that the Sol-Arks are controlling charge & discharge (which I'm not convinced of), am I using the optimum settings? I see others posting slightly different battery settings than I have.
Float V: 56.3
Absorption V: 56.3
Equalization V: 56.3
30 Days, 0 Hours
Shutdown: 20% (46v)
Low Batt: 30% (47.5V)
Restart: 40% (52V)
Batt Empty V: 47
Batt Resistance: 8mOhms
Batt Charge Efficiency: 99%
Batt Capacity: 600Ah for 6 batteries
Max A Charge: 185A (maxed out & low for 6 batteries, IMHO)
Max A Discharge: 185A
More questions to come as I try to use the system to its full potential.
Float V: 56.3
Absorption V: 56.3
30 Days, 0 Hours
Shutdown: 20% (46v)
Restart: 40% (52V)
Batt Empty V: 47
