fmeili1
Hi,
I wonder if the EG4-LL (V2) still has the pre-charge resistor and if it does, is the procedure the same to activate it like in the EG4 LifePower4? I found Signature Solar videos about the correct pre-charge cycling of the EG4 LifePower4 battery, but NOT for the EG4-LL (V2). Also, in the manual of the EG4-LL (V2) there is no pre-charge resistor and sequence mentioned but it is in the EG4 LifePower4 manual!
If I try to use the same procedure for the EG4-LL (V2) which is described for the EG4 LifePower4, I don't have the LED lights cycle and also don't hear a click noise like the EG4 LifePower4 does?
Until now, I've only done some "dry" tests to activate the pre-charge cycle on the battery - without the inverters connected. Maybe the pre-charge cycle only starts, if an inverter is connected (I guess this is not the case, but I don't really know)?
For EG4 LifePower4 I found the following procedure to activate the pre-charge cycle:
Maybe I need to activate the pre-charging in the BMS-Settings?
In the BMS Tool I found in the tab "BMS Control" a section labeled "Charge OCP Model" with the following possible radio-button options:
So the important questions in short are:
Does the EG4-LL (V2) has a pre-charge resistor and cycle mechanism at all?
Do I need to enable it in the BMS settings or should it be just there?
Is the same pre-charge sequence used for the EG4-LL (V2) batteries like described for the LifePower4?
Is it ok to not see LED's cycling and no clicking noise like the LifePower4 does or should this happen also with the EG4-LL (V2)?
Does the pre-charge cycle happen even if no inverter is connected (I'm aware, that it would not charge anything even, if the cycle would happen)?
Thanks!
- Turn off the batteries (the BMS buttons and the breakers on the front of the batteries) - this step I've not done yet.
- Connect the inverters to the batteries (switch on the breakers between the batteries and the inverters)
- Switch on the BMS of the batteries
- Switch on the breakers on the batteries - this step should start the pre-charge cycle for a couple of seconds.
- No Current Limit Protection (this is activated!)
- Current Limiting Charging
- Precharge Protection
- After Charging Limit
- Precharge+Charge Limit
Thanks!
