mathewhgreen
- Apr 5, 2021
- 29
Hi
The controller I have is capable of upto 100volts of panel voltage.
I have two 290watt panels I want to put in series having had them in parallel for ages. I have three of them in parallel at the moment.
I’ve not had an issue with over-panelling as the total power was nearly 900 watts as the voltage was never higher than 35volts. The amps being controlled by the controller.
If I put two of them in series which will total about 70volts will it be ok still?
Just checking before I change
I just fried what I thought was the same controller but the voltage was limited to 60volts. A capacitor has popped so hopefully changing that out will fix it. I can’t see any other damage.
Thanks
Mat
Thanks
Mat
