Hello I have a 4215BN, 4 - 6v gcart batteries and 3 - 270w 39v 15a solar panels 3p. A 2000w inverter with two 120v. 1 showing 100v the other 110v
The Charge controller shows 40v but never above 3amps, full dun shade, clouds... 3 panels in parallel should be close to 30amps.
The panels are:
72 cell, polycrystalline
Specifications:
Rated Power: 270W
Open circuit voltage (VOC): 44.4 V
Max power voltage (VMP): 35.5 V
Short circuit current (ISC): 8.25 A
Max power current: 7.60 A
Power Tolerance 0/+3%
Maximum system voltage: 600V (UL)
Fuse Rating: 15 A
IP65 Junction Box w/MC4 Compatible Connectors
Frame: Anodized aluminum alloy
Weight: 61.7 lbs
Dimensions: 77 x 39.05 x 1.81 inch
The batteries are
Les Schwab GC2-6V,
105 min @ 75a (no clue what that means)
Marine deep cycle
Wired 2s2p
Would wiring it as 24v instead of 12v
One post I read here indicated the charge controller would output what the system called for so I ran the inverter heavy. It would not run s vacuum. My 110v LED lights were flickering.
Am I missing something or should I reasonably expect 750w at 35v would show more than 40v at 3 amps under load?
Thank you as always for all the insights.
The panels are:
Specifications:
Rated Power: 270W
Fuse Rating: 15 A
Weight: 61.7 lbs
The batteries are
Les Schwab GC2-6V,
Marine deep cycle
Wired 2s2p
