Been using my system for a while without any active data or data-logging so it's about time to sort that out. Off-grid for most of the year so usually let the bulk-charge finish before any heavy loads, then overnight on batteries.
The Epever Tracer AN 100A MPPT solar charger is different to previous models in that it only has solar-in and battery-out cables so the connection to inverter is external. The Epever display has graphic and values for load current but no obvious way of informing the charger what the value is so it's always shown as zero. I am using the MT50 remote display installed next to the charger as it's easier to change settings for the charger with that than the buttons on the charger itself. The MT50 does have a ModBus RJ45 socket but I'm struggling to work out if I can feed inverter data into the charger to make charging independent of other loads.
I'm not particularly familiar with Ethernet and WiFi so I suppose that explains my hesitation in the first place but, it also seems possible to spend a fortune on clever little boxes with no real idea if they will actually talk to each other!
Victron documentation is very good but Epever just serves to confuse me. Victron say that the VE-Bus for the Quattros are "mission critical" so there is no third-party option to connect directly to that bus. I can see that the Victron Color GX display can connect to the Quattros' VE-Bus and also appears to have ModBus capability. What I really need is for someone to reassure me that has possibly done something similar before I fork-out hundreds on the bits that I think I need.
So it all boils-down to whether the Color GX can tell the Epever what the load is so that the Epever can make the best job possible of charging the batteries?
I did install everything myself including the solar panels (literally on my own) and the system is working really well but, I'm getting-on a bit in years and it's not so easy now to learn all of the new stuff that I need to know.
Many thanks if you can help me.
