Hogheavenfarm
Regulation Stifles Innovation
- Jun 24, 2022
- 460
No.Ok, here is a screenshot -
I had the wires from the light connected at "1", I believe I should have them connected at "2" and a separate power feed going into "1"
Thanks for the pictures.
Just FYI for anyone else planning on adding things to these ports as they go (yes even the remote battery temperature plug), it is far easier to make all these wiring hookups before mounting the SCC while you can still see the ports. Once mounted all kinds of impediments to reaching these areas...View attachment 126409
…and then support the wires so the little connector isn’t bearing weight.connect the wires to it and then plug it back into the controller.
The "N" on the AN, BN etc series designate them as "Negative Common" (positive switched), so the negative terminals are always tied together.With the breaker open it gives continuity between batt(-) and load(-) but no continuity on pos(+).
I guess I’ve never bought anything typical?The typical non-MPPT SCC is 'positive common' (negative switched).
Good for you!I guess I’ve never bought anything typical?
I set mine toWould like to hear from someone actually using this, how did you do it?
