sgtcrumb
- Mar 8, 2022
- 27
Hi All,
I'm looking at the Epever Tracer series, and particularly the 40A BN variant (see https://www.amazon.com/dp/B08CN1QZXF/ref=emc_b_5_t?th=1) to possibly pair with a couple Rolls S6-GC2-HC golf-cart batteries (see battery specs here: https://rollsbattery.com/battery/s6-gc2-hc/). The recommended charge current is 30A for these batteries. I will have two of these 6-volt batteries in series for 12-volts, and 241 AH. Charging voltage range is up to 15V. Loads will consistently range between 20W and 50W. Not much, but they need to be accounted for. Given my rough math, the charge controller should be able to supply up to 35A @ 15V = 525W. Since solar panels almost never produce their STC numbers, I would want 650W or more of PV.
Questions:
1. Is it safe to over-panel the Tracer charge controllers? The 40A tracer charge controllers show a Max of 520W PV input, which will provide a max of 34.7A (520W/15V). This is probably close enough for my needs. Typically, I assume PV panels will provide a max of 80% of STC, so the array STC would need to be ~650W or more.
2. Can the Tracer be programmed to limit the charge current? I know the voltages can be customized. But I need the charge current to be adjustable, probably starting with an initial setting of ~33A and increasing if needed.
3. Do high-voltage strings of panels work well with this controller or should parallel panels be used instead? For example, would this controller work efficiently with three 240W panels in series having a Voc of 37.6V per panel (total of 112 Voc @25c, 135Voc @-25c)? The voltages fall within the controller's listed limits.
Thanks!
Questions:
Thanks!
