My thread disappeared so trying again. Cutting to the chase will a EU inverter L/N/G on 240v run a standard American 30 gallon 4500w 240v water heater? If so what would be the best way to wire it up?
The wiring is all the same to L/N/G. Most American devices are 120Vac, but since the water heater runs at 240v, I think it will work with the 240v inverter.
Thanks! It's a double element and I've seen people talking about parallel and series wiring but as I understand it series will reduce the voltage to each element. Is that correct?
