rustythorn
hypothetically theoretical
not sure where commercially available portable power stations [aka solar generators] discussions should live so please move this thread if need be.
i'm hoping someone has already done some digging on this to save me time/hassle, i want to know the current/future portable power stations that can simultaneous receive 120 VAC [10 amp minimum, preferably 15+] input while outputting 240 VAC split phase. i know there are several models out their that can output 240 VAC split phase. most/all of these require two units hooked together some examples are from ecoflow, bluetti and hysolis but there are others. i'm hoping to find a setup that has total storage with 3-10 kwh and max output [240 VAC split phase] of 3-10 kw. many/all of these units have sketchy or hard to find info on how much input power can be supplied at 120 VAC while they are outputting 240 VAC.
the perfect unit for me would be one that allows enough 120 VAC [10-15 amp minimum] and solar input to equal to its 240 VAC output but i would settle for half. Will Prowse just did a video on the new updated Hysolis Apollo 5K set up as a pair for split phase 240 VAC and said it could be given 737 watts of 120 VAC [though the manual says 600 watts] while configured this way. if both units could each receive this for a total 1474 watts i would be happy but i've yet to get clarification on this. it would also be nice if one unit could be used instead of two, the new Anker SOLIX F3800 might work but info is still scarce.
TL;DR
the main question i'm asking is: when two units are paired for split phase output can each unit receive their own 120 VAC input? what is the total input and can that input be from the same outlet?
TL;DR
