Here are the specs for the battery. I'm not sure what calculations will give me the answers you seek. I did buy 4 of these packs. I really appreciate you all taking the time to answer my questions.
This battery box includes the following:
(1) 24V A123 LFP Battery
(1) 130A 8S BMS
(1) 24V A123 LFP Battery to 8S BMS Adapter
(1) 24V A123 LFP Battery Box
YES – you can connect Parallel for increased capacity. (Up to 8)
YES – you can connect in Series for 48 volts. (Up to 4)
Electrical Specifications
Nominal Voltage: 26.4V
Voltage Range: 20V – 28.8V
Nominal Capacity: 2.45kWh (92.8Ah)
Configuration: 8S5P
Energy – 100% DOD, Nominal: 2.6 kWh
EV Energy – 80% DOD, Nominal: 2.1 kWh
Chemistry: LiFePO4 (LFP)
Cell Type: 20Ah Nanophosphate Cells
Cell Count: 40
BMS Specifications
Single cell overcharge protection voltage:
- Min: 3.72V
- Standard: 3.75V
- Max: 3.78V
Single cell overcharge protection delay time:
- Min: 0.6S
- Standard: 1S
- Max: 1.5S
Single cell overcharge recovery amperage:
- Min: 3.5A
- Standard: 3.6A
- Max: 3.6A
Recharge current:
Single-section equalization voltage:
- Min: 3.55V
- Standard: 3.6V
- Max: 3.65V
Single-section equalization current:
- Min: 35mA
- Standard: 40mA
- Max: 45mA
Single cell over-discharge protection voltage:
- Min: 2.15V
- Standard: 2.7V
- Max: 2.8V
Single cell over-discharge protection delay time:
- Min: .6S
- Standard: 1S
- Max:1.5S
Single cell over-discharge release amperage:
Discharge protection current:
- Min: 350A
- Standard: 370A
- Max: 390A
Charging high temperature protection:
- Min: 85℃
- Standard: 90℃
- Max: 95℃
Physical Specifications
Length: 18in
Width: 10in
Height: 8.5in
Weight: 60lbs
Operational Specifications
Operational Temp Range: -30℃ ~ 55℃
Storage Temp Range: -40℃ ~ 60℃
