Hi all. I have a Factory reset EPEVER UP3000 M6322 (24v) all in one off grid Inverter/charger. It has been working fine. to day I made an adjustment to the the low voltage disconnect and reconnect values via the android app. (First time I have used the app). I also adjusted when the utility charger will take over. all adjustments were very slight and well within the parameters of the unit.
Now I have an issue. When the battery is supplying the power to the inverter the output load turns on and off every 10 seconds or so. If i switch the output to utility all is fine. There are no fault lights. Im guess in may have entered an incorrect setting. I have changed made sure all settings are at the default settings but issue is still there.
I wanted to do a factory reset to ensure all internal parameters are correct but I cannot find a reset procedure in the manual.
The battery is a Lithium Ion 7s320p (18650) 24v Power bank. All 7 cells are well balanced and the voltage output is stable. all connections checked and all ok.
I'm hoping someone knows what the issue is or knows how ro reset the unit.
Thanks in advance
Thanks in advance
