G'day all
I'm hoping to get some feedback on a large system that I'm currently planning for.
I've included a rough schematic of the system - so basically it's 4 arrays of 6kw solar incoming (total 24kw). Batteries will probably be REPT or EVE 280 in a 4p17s config - total of 62kw. Battery busbars will be custom for the high amps (will limit to 300).
I'm going with the Batrium BMS due to the high amps - using NOARK circuit breakers with shunt trips. In case of a critical fault I want to simultaneously disconnect both battery and arrays - as I understand the batrium only has the ability to use 1 relay for a critical fault - which is just a pulse of 24v to the shunt in the circuit breaker - I'm hoping I can just parallel the power to the shunts to operate simultaneously.
Any feedback most welcome. And please excuse crappy diagram...
Thanks
Thanks
