robbob2112
Doing more research, mosty harmless
Charging the battery while connected to the UPS might damage the UPS. Just depends on the charge circuit.
The UPS presumably expects a much smaller battery than you 100ah of capacity. If the UPS charge circuit expects a 7ah battery it will only put out around 1/2 amp of current. But it wouldd be build with the idea that the battery will be topped up in only a couple of hours. But yours would run until it over heats. If that happens enough it will burn that out.
Small ups are almost always the type that run from wall power and just trickle charge the to keep them topped up, or recharge after an outage a few times a year. If you deliberately run from battery all the time it may as well be an inverter. It will overheat after enough time.
