robbob2112
Doing more research, mosty harmless
Get a real inverter with the capacity you need to run your computer monitor, computer and modem.... Figure out what those total up to... Add 20%..... get a real one ... Get one that is actually supposed to run at that rating so when it runs it is only just warm to the touch when running.
This will probably cost you 3 times or more as much than the cheap ones that are running so hot.
For instance - my real 1000w inverter is the size of a shoe box... 12in long by 7in wide by 5 high.... when I put a 600watt load on it the internal fan runs and it stays cool to the touch on the outside.... it cost me a bit over $400us ... it is a low frequency top tier.
I can get a top tier HF inverter for $150 that will run just warm to the touch with that load. The diminions on this are 11in x 7in x 3in ... it will have two fans in it to keep it cool.
So figure a real one will cost you around 8000p ---- your hard task is to get a real one verse a fake one for that price.
