SenileOldGit
- Oct 15, 2022
- 320
Hi, I have 12kW of ground mounted solar panels, two rows of ten Canadian Solar 595W. I store bags of sand and cement under them, under a tarpaulin, and crates of assorted household 'junk'. When I mounted the panels, I left a 1-2cm gap between them, because I thought it would allow some of the wind to blow through the gaps, and thus would make the panels more secure in high winds. (They are mounted on scaffolding poles which go into ground screws). Since I have watched them remaining rock solid in even the highest winds, I no longer worry about them needing the gaps - but I want to stop rainwater from falling onto the things I have stored underneath the panels. I don't want to manually move all of the panels so that they are touching each other (and even that might not stop all the water from coming through) - is there anything I can put across the gaps that would stop rainwater, and last a decent length of time? I have thought about Duck tape, but I thought I would ask here in case anybody else has already had to do this, and had found something better for the job.
