Berseker
- Mar 22, 2020
- 269
I have 4 x 12v 220ah luminous fla batteries, that have served me since 2016. they are hooked up to a mustpower 48v 4kva inverter, on charge settings 58v absorb and 53,2v float 23amps max charge current and i manually equalize @ 61v for some hours every month or so, am partially offgrid. recently i noticed that they are getting unusually hot during absorb charging and boil/bubble moderately as well, making me double check to be sure i didnt mistakenly leave it on equalize.
some cells have the electrolyte a bit discolored, while majority are clear as plain water. i also notice some cells go down and need topping up more frequently than other cells, within 2weeks versus 5 to 8weeks for other cells.
i reduced the charging voltage to 56.4v adsorb and 53.2v float, and it didnt get as hot as it usually gets, however noticed a drop in battery performance, as voltage quickly dropped to 49.2v underlslight loading , instead of the usually 49.6v after 3 to 4 hrs under the same load
Has anyone experienced this, and any possible remedy?
i am thinking along the lines of draining the whole electrolyte, cleaning the internals of the battery, by flushing water through it, and refilling with clean good electrolyte. however i have heard of many horror stories of folks whose bank failed instantly or went steadily down hill after such an attempt.
waiting for tips/suggestions on what to do next
