Lonlywolf65
Hello all. My name is David I live in Minnesota and decided to try solar to help with my utility bills. Lets start with the basics....I bought a 400 watt "kit" from HQST... nope not the best but fit my budget... I spent the summer gathering the extra parts needed , cables breakers and such... The last components were the batteries which are 3 114 ah everstart max and 1 everstart max 122 ah all 4 are FLA batteries. in parallel as are the 4 100 watt panels. I also added a couple meters to observe the various other info amps volts capacity. 1 of the meters is a low voltage alarm.... I am currently at work and not totally sure of all the settings required and will get to that as this as this thread grows...
fully charged voltage?
Float?
equalization?
bulk?
Boost?
And any other possibly related numbers.... I have noticed that different vendors use different terms for same item..??
Any help with these numbers will be greatly appreciated!!! Thank you in advance Dave
Float?
equalization?
bulk?
Boost?
