sunshine_eggo
Happy Breffast!
my float is currently set to 55.2 I didn't lower it yet, and it has been there for well over an hour, I don't want to turn it off yet so as soon as I am done with the measurements which I'll wait another couple hours to do then I'll set it to 54 like the crown specs.
I would accept an elevated float voltage.
if the grid is on I use that to charge, smoother current than a generator no?
Yes. Sorry. Anything but solar.
All my wiring to the batteries is exactly the same length. I will try to notice if it bubbles at rest again and see if I can find a current.
here's why I was confused with the DOD, this a typo or editorial mistake then right? D being depth means lower is less higher is more, "below 50% DOD" would literally mean a lower number and that would be less DOD, a smaller load, "50% and above DOD" would be a higher number, more DOD and a bigger load.
and this is the water diagram, that is where I keep it, it has never been lower than an eight to quarter inch below this, some months it didn't need any at all
Yeah, that's worded a little back-asswards, and it includes that "generator" comment. It's correct if you replace DOD with SoC.
