Mannfamilywoodworks
I’m trying to figure out if my piers I’ve built are strong enough to hold my shipping container.
The 45’ container empty weighs 5 tons.
I have roughly 50 pieces of drywall, over 100 or so 2x4s, appliances, furniture etc etc. I’d say around 2 additional tons of materials inside.
So 7 tons total weight roughly.
My plan is to start with two piers on the high end of the container.
I dug down as far down as I could go for my footing.
The frost line in my area is at 42” below grade.
I got about 20” down below grade. I hit a massive rock face.
I went to the other corner.
Same situation.
I went 8 feet back.
Same situation.
8’ to the other side.
Same rock face 20” or less below grade.
Okay I’m building on top of a ginormous rock.
So I drilled into the rock with a 1/2 bit and I stuck re bar into the rock. I poured a 32”x32” footing with the rebar into the rock.
After that I began stacking 8x8x16 cinder blocks to get to my desired height of around 40”.
Now I’m going to make a temporary support system out of 6x6 timber’s and jack the container up an additional 10” and it will be perfectly level and I’ll continue with my block pier foundation.
I tied the re bar into the rock, through my footings, and tied an additional piece of rebar through the cinder blocks, I then filled those solid with concrete.
How much weight do you think one of these piers can handle?
I’m going to be putting them every 8’ on each side of the container.
when I’m done I’ll have 10 piers total.
Thankyou if anyone has any structural knowledge.
Same situation.
I went 8 feet back.
Same situation.
