Er805
Hello, I want to know what system would be best to charge an electric transit van off of solar panels for 1-4 hours a day?
You can start with the available area on the top you want to dedicate to the solar panels.
Realistically, you can't expect to charge more than 5-6 kWh per day, but it's still feasible.
Yeah! We need more details.I didn't even assume the intent was to charge from van-installed solar...
I don't think $$$$ would be the issue but space. The Transit electric is 68kWh.... I don't think a transit van could fit 68kw of solar panels and mounting hardware to charge in an hour. Even in a day (5 hours solar) that's 13.6kw of panels. He'd need to lay out across like 10 parking spots lolI suspect that it will not be realistic to fully charge an electric tranny in one hour unless you have $$$$$$
Well, to do it properly, you will need battery storage equal or larger than the van has… and an array capable of feeding them in an average day.Hello, I want to know what system would be best to charge an electric transit van off of solar panels for 1-4 hours a day?
while yes, we do need more info on this project, based on what they wrote we can't assume they meant they wanted it fully charged in 1-4 hours, it could be that they will only be charging it from solar for 1-4 hours a day.and in addition to the above questions...
What is the capacity of the vehicle?
How far will you drive it a day?
