justinm001
Solar Addict
- Dec 18, 2022
- 1,538
I remember either dometic or norcold manuals has the temp differencial that they're rated for and I believe it's like 35ish degrees.you still need to vent a compressor fridge if you do not want the A/C have to expel the heat as well.
I've never seen a residential fridge externally vented before. It's a refrigerant based system vs ammonia and the heat expelled is not much at all and I haven't been able to capture on flir
