Brucey
Solar Wizard
If you want real redundancy I would just have three separate pairs of inverters, each with a 5 pack of SOKs and a 450/100
When you link Victrons either as split phase or parallel or both, if one of the inverters turns off for whatever fault condition, the others will also shutdown. you'd then have to take manual action via ve config to reconfigure them to work with a set removed from the configuration.
