Fuse amp and location question
WNCGUY
I plan to install a Victron IP22 30A battery charger in my van that will be used to provide shore power to two 100ah LiFePO batteries, the charger cables will have an Anderson connector to allow connection of alligator clamps in the event charging a car battery is needed. Charger will hard wire to a Victron power in that has fuses added (Explorist Life hack).
The charger has a built in 40a fuse, 6awg cables will be used.
My question is. Thay amp fuses are needed and at what location should they be placed. Example in the Victron power in and the 6awg cables.
