Wv lew
Newbie here. Thanks in advance for helping me. I do electrical stuff all day long but new to solar. I’m just starting to install phase one of my solar, so right now it’s an eg4. 6000 ex, 12-Trina Solar 280 watt panels ground mount, and 1-eg4 LL 48 volt battery.
A couple questions;
1st, does the all in one 6000 ex by eg4 have any overload or short circuit protection built in for the solar input, or for the battery output etc? I would think it does, but who knows.
2- I looked at will prowse design for the split phase eg4 6500’s and he has breakers and fuses. Can I use a breaker to the battery output? I am thinking of using the Nader dc circuit breaker from signature solar, more specifically is that ok or even needed since the eg4 LL48 battery I’m using has a built in breaker?
3- what kind of overload /short circuit protection do I need on my solar, right now all I have is the disconnect which doesn’t supply any protection it just disconnects. In hindsight if the all in one inverter doesn’t have any protection for it, maybe a breaker here would have been smarter than a disconnect as the breaker can also serve as a disconnect. Any suggestions for a breaker for the solar pv input?
Thank you
A couple questions;
Thank you
