If the battery doesn't have a built in fuse of breaker -
A MRBF fuse of the appropriate size mounted on the battery terminal. The correct size is 20% higher than the rated output of the BMS. The wire should also be sized to 20% higher than the BMS can put out.
IF the distance from the battery to the cut-off switch is more than a foot or so it would be good to add a second MRBF at the input to the cutoff. This is in case there is a short someplace along the cable.
With multiple batteries in parallel this is more important. And if you have 3 or more in parallel you may want to consider class T fuses.
The MRBF requires a mounting block as does the class T. The reason for these is they have a higher AIC than the Mega and ANL style fuse and lower resistance so they generate less heat.
Don't trust amazon for fuses, to many fakes - stick to Del City or mouser for the MRBF and you can get the class T from amazon IF they are Littlefuse, Bussman, Eaton, or Blue Sea Systems (relabeled, made by the other 3)
Also make sure to use no-ox-id special or equivalent on all mating surfaces - it makes for a better connection and inhibits corrosion.
