Fuse size for prismatic cell bank?
tammons
USA
I am building a few 12v 4S battery boxes using prismatic cells to power refrigerators/freezers when the power goes out, and for general use camping etc, and I am confused about the main fuse size for the + battery terminal.
So far I have built a 100 amp with the cells and BMS scavenged out of a Renogy battery and it is working great. Right now I have a 150 amp fuse on it. I have a 120 amp anderson plug (which is also fused) feeding a 1200 watt PSW inverter. All the accessory plugs/outlets are fused to around 120% +- of the outlet rating.
I am in the middle of building a 150 amp box and almost finished. Originally I thought a 200 amp fuse for this one, but now with a 1200 watt inverter, I am thinking a 150 amp main fuse would be best. Would this be correct? This one has a built in 1000w inverter but will run up to 1200 watts.
Next will be a 300 amp 12v 4s box. This one I doubt I will ever use the full 300 amps, so do I size the main fuse for the heaviest load I expect to encounter or main fuse it at 300 amps?
Thanks
There is the key to the fuse sizing.
The inverter will be drawing 1200W/12V = 100A. Fuses should be run at 125% of the max continuous current so the proper fuse size is 125A. The wires between the battery and inverter should be sized for 125A as well.
Since it is a PSW, we could argue that the fuse and wiring should be larger due to the phantom load but for this system 125A is probably fine.
Fuse to the load.... not the battery capacity.
The next question is... I have a battery terminal fuse and also a fuse for the 120 amp anderson connector.
I have been thinking having both is redundant?
Yes but..... What kind of fuse are they? What is their interrupt rating?
Just a sample to look at
My cpap backup also does the fridge in a pinch. My fridge is newer and draws around 300w. The cpap draws between 10w and 90w. Both cycle a lot.
In real life the cpap uses 270Wh in 10 hours. The fridge runs 14 hours on 1100Wh or so. Just have to keep the door closed.
I did this 8 months ago and have only used it once for the fridge but I use it every night for the CPAP.
Technically the wire should be 4awg to the inverter and the fuse should be 100amp, but since I never intend to use it close to limits I haven't taken tome to change those. I could also just swap the fuse to 80amps and be good.
