I have (3) 220 Amp Hr LFP batteries. Each has a BMS of 150 Amps.
Each battery terminal has an MRFB 200 Amp fuse. 4/0 Cables from the batteries will each tie to a 1000 Amp busbar, which is then protected with a 500 Amp Class T fuse before the disconnect switch.
Am I correct in believing that 150 Amps BMS x 3 batteries, 450 Amps potential, needs a 500 Amp fuse?
And that each battery cable is correctly fused at 200 Amps?
