Hi,
I'm trying to get my head around which forms I need to complete for DNO approval in the UK, and quite frankly it seems to be a minefield !!
My set-up is very simple.
16 x 385W panels (east/west facing so ~5kW solar generation max if I'm lucky), Solis 6kW Hybrid Inverter (RHI-6K-48ES-5G), with 3 x 4.8kWh pylontech batteries.
I want to consume all the electrons I cultivate and never want to export power to the grid and will set-up the inverter accordingly.
But it seems that even if there is no export, DNO and G99 approval remains mandatory because I will parallel to the grid, but can't quite get my head around which form is appropriate.
The inverter is fully G99 compliant - ENA Type Test Compliance Number SOLIS/03855/V1
and G100 compliant to limit export to 0kW.
So can I fast track through form A1-2 : Application for connection of Fully Type Tested Integrated Micro Generation and Storage installations
But I struggle to answer the question :
Or do I need to go through a protracted G99 application with form A1-1 : Application for connection of Power Generating Module(s) with Total Aggregate Capacity <50 kW 3-phase or 17 kW single phase
Which seems barmy for such a simple configuration with no export !
Any advice greatly appreciated for me and any others from the UK on the forum !
for a 6kW inverter, or is it compliant to this question if export is set to 0kW ???The total aggregate capacity of the Power Generating Modules that are Electricity Storage devices do not exceed 16 A per phase and the total aggregate capacity of the Power Generating Modules that are not Electricity Storage devices do not exceed 16 A per phase.
