Hi, new to the board. I'm a tinker'r. Fairly savvy in electrical and electriconics; Avionic is USAF, 1st Class FCC Commercial when they use to issue those, Extra Class Amateur Radio. Finished my career as a house electrician and lighting director for a large performance venue (5 venues actually, small to large). So here's my project.
Please, with each post I'll have one main question or concern. I know there's lots of things you'll just can't wait to share with me, but if we can make this a simple step-by-step thread to follow much better for my feeble wit.
OVERALL PROJECT IDEA
Priorities:
Save money: While N. GA has some of the cheapest electricity (~$0.15/kWh, fully burdened), it's going to go up. I've configured systems on paper in the past and they don't usually save money, unless someone else is paying, think rebates. So I'm aware this. Don't need to labor on it, what money I don't save can be thought of as applying to next priority.
Emergency Backup: It doesn't happen often, maybe once a year and usually only for 15 minutes or less, but it has been down for 6 hours once recently. Who knows however what the future will bring. Don't need to run the whole house, just enough to make it comfortable. The freezer, a few lights, some fans, maybe the TV for OTA, and oh, the garage door opener. I can justify a 15yr payback by claiming that part of that was paying for emergency backup.
Experiment: It's my nature. Spent the Wuhan flu season learning and playing with Arduino. Built a clock (doesn't everybody?) a reloading monitor and counter for my reloading bench, and a Halloween light and sound controller.
What I've considered:
Not willing to try whole house at this point. There is a challenge with my roof as it all faces East and West, however I believe I can get a small number, 4 cells, mounted on a frame work on the 1st floor roof over the garage. That way they'll be facing south. Plus they'll be right over the garage where the system will be located.
Considered and discarded a number of appliances and finally think the most cost effective will be those things right around the garage. Clothes dryer and washer, the freezer, the outside security lights, the garage lights and the garage door opener.
What I've configured so far is a 48V hybrid inverter, 240 split phase. 200Ah of LiFe batteries and four 300W+ cells. Currently it prices out about $6,000 and a 12yr payback (straight line no interest) with the new 30% rebate.
Today's question:
It's about mating the Inverter to the PV cells. Four cells in series will give me ~130v,. The first inverter I zeroed in on was the Sun Gold 6kW split phase inverter (TP 6048). I like everything about it EXCEPT the lower end of the MPPT operating voltage. Most other inverters list 60V-450V, or there abouts, but this Sun Gold is spec'd at 120V-450V. It's the low end I'm worried about. The example in their manual show 6 panels as a low end system, though they don't mention or caution about going with fewer. Not sure I have room, nor spend the money for 6 panels at this time.
Will 4 panels be enough to drive it? Why is this one inverter of this class have a higher minimum PV voltage than any of the others?
(And before you you ask, yes, I've spec'd out the appliances and four 350W cells, 5 hours a day, will provide the weekly needs.)
TIA
Priorities:
Today's question:
TIA
