Dr.Bannock
I hooked up my generac, which has the 2 wire start stop, to my Growatt 12kW with the dry contact (NC and C are connected to the wires) but for some reason the generator doesn't start after I drained the EG4-LL batteries a little to have the possibility to test the automatic switch function with some settings in the inverter. If I just close the loop of both cables before the are connected to the inverter, it starts instantly, but not when connected to the inverter.
The manual says, that the contacts should stay open to start the generator, which is the opposite, what happens, when I tested manually or connected to the inverter. Therefor I am confused because my configured condition seems not to shut the.
Any idea, what I could do?
