Hello experts,
I have the following case:
due to quite complex installation in home my grid tie and hybrid inverter have different injection points of AC.
IN case of blackout I am planing to disconnect from grid and change the injection @ hybrid inverter from AC in to backup output.
THe backup function might work properly, but I am worried about the behavior of Grid tie inverter connected to the same injection point and they will of course wake up and start synchronizing to backup output and inject full power. The power limitation might not work anymore and string inverter will try to pull full power and destroy AC backup output.
ANy thought or maybe practical results from you ?
Inverter are the following:
Hybrid : GoodWe GW5048
String: 2x Sunnyboy 2.5k from SMA
thanks in advance
thanks in advance
