burgerking
Is there a similar website that plots the chart of solar output vs time of day?Another issue is angle. I worried about this - probably too much - as I didn't really understand the impact of the choices.
Suggest using PVWatts - https://pvwatts.nrel.gov/pvwatts.php - for your location with the defaults and just play with Tilt (deg) to see the different kwh estimates based on the different angles.
You may want to optimize for winter or summer or in-between or make it changeable. The angle may worry you more or less - but at least you can put some actual numbers to the design choice you settle on
ie, I want to orient the panels East, South, West and want to know how the output appears.
