live4soccer7
- Jun 15, 2020
- 670
I am looking at a 25kw installation, however I am torn between whether to go with a ground mount install or a roof mount on my shop which is a 50x100'.
I always thought I wanted to go ground due to accessibility for maintenance, replacements, cleaning, snow removal, etc.... I also figured that roof mount would inevitably cause leaks and then if you have to work on the roof then you have to REMOVE the solar system which would be a massive PIA. I do have space on the ground in a field near the shop somewhat. The shop would sit on the north side of the panels.
Roof Installation pros/cons from my perspective. They'd be out of the way and off the ground and would probably get a little better productivity as there would be no possible obstructions from the shop or other trees in the far out distant.
Anyone have any suggestions?
