wiseacre Solar Addict Joined Aug 8, 2021 Messages 527 Location North of the Adirondacks May 10, 2022 #1
HRTKD Boondocker Staff member Moderator Joined Apr 24, 2020 Messages 10,018 Location Somewhere South of Denver May 10, 2022 #2 Does it work equally well if I use coffee "grounds"?
D DThames Solar Wizard Joined Nov 22, 2019 Messages 2,664 May 10, 2022 #3 The wire is not nearly long enough! Need at about 8 feet of wire and a larger ziplock.
12VoltInstalls life passes by too quickly to not live in freedom Joined Jan 18, 2021 Messages 7,043 Location Vermont May 10, 2022 #5 HRTKD said: Does it work equally well if I use coffee "grounds"? Click to expand... You shouldn’t do things that cause a ground loop. Only one coffee ground will work safely.
HRTKD Boondocker Staff member Moderator Joined Apr 24, 2020 Messages 10,018 Location Somewhere South of Denver May 10, 2022 #6 I don't know. If I get enough coffee in me I get pretty "wired".
WYtreasure It's not happy hour, I'm just like this. Joined Nov 23, 2021 Messages 1,707 Location Thunder Basin Wyoming May 10, 2022 #7 The ground wire needs to be secured to the door so it doesn't flop out and short.
WoodsieLord New Member Joined Oct 4, 2019 Messages 145 Location Buenos Aires, Argentina (230V monophasic, 50Hz) May 11, 2022 #8 I don't want to be a d*ck, but the man in the video is using some sort of Pot mixture. I have reasons to believe he might not be a true gardener
WYtreasure It's not happy hour, I'm just like this. Joined Nov 23, 2021 Messages 1,707 Location Thunder Basin Wyoming May 11, 2022 #9 WoodsieLord said: I don't want to be a d*ck, but the man in the video is using some sort of Pot mixture. I have reasons to believe he might not be a true gardener Click to expand... His eyes didn't look red but some sort of Pot ? mixture was probably a contributing factor in creating the video.
W Warpspeed Solar Wizard Joined Jun 11, 2021 Messages 1,526 Location Melbourne, Australia May 15, 2022 #10 It has to be genuine Earth. Even the Apollo mission to the moon carried a small bag of Earth to ensure complete electrical safety for the astronauts.
rin67630 Solar Enthusiast Joined Apr 29, 2020 Messages 1,077 Location Nort-Rhine-Westphlia Germany May 15, 2022 #11 Good idea! Just add some water from times to time to keep the moisture... At the current prices for copper, I begun gardening electrical wires too.
WYtreasure It's not happy hour, I'm just like this. Joined Nov 23, 2021 Messages 1,707 Location Thunder Basin Wyoming May 15, 2022 #12 rin67630 said: Good idea! Just add some water from times to time to keep the moisture... At the current prices for copper, I begun gardening electrical wires too. Click to expand... What happens if your potatoes ? grow around your grounding wire? Won't you be sending voltage into the system?
MrNatural22 ?SW sunshine =⚡️⚡️lit up thru the darkness✌️ Joined Sep 20, 2019 Messages 1,648 Location 1000 miles to somewhere May 15, 2022 #13 Copper does go green when wet......So grow ya batch..
