fisherman
Good Morning,
Offgrid cabin here. Currently running a small generator into my AC panel but plan to install solar soon. So the generator would then connect to the inverter and supplement the batteries when needed or when needing more power.
I'm planning on mounting a few rooftop panels for my setup and was wondering if someone could explain how to bond/ground them. I already have a grounding plate 2ft in the ground that is tied to the A/C panel in my cabin.
When installing the panels and inverter, how should they be bonded/grounded within the system to connect to the AC panel in the cabin?
Thank you
Thank you
