Rednecktek
Solar Wizard
You only say that because you're not here taking cold showers.I would love to live in your back yard!
Is that by choice or no water heater?You only say that because you're not here taking cold showers.![]()
The on-demand I had plugged in (until earlier today) was a weeeee bit undersized for the ground water temp. The new one should be much better.Is that by choice or no water heater?
I use a propane OD with a preheat tank in the cabin. That preheat really saves on time and energy/fuel used.The on-demand I had plugged in (until earlier today) was a weeeee bit undersized for the ground water temp. The new one should be much better.
Yeah, I'm using the shower to test run models and performance to eventually replace the propane water heater in the cabin. It eats a LOT of propane.I use a propane OD with a preheat tank in the cabin. That preheat really saves on time and energy/fuel used.
The electric ones I looked at want 60A at 240VAC. I suppose that it would actually save power over a standard heater depending on frequency of use, but that seems like a very high demand.Yeah, I'm using the shower to test run models and performance to eventually replace the propane water heater in the cabin. It eats a LOT of propane.
Have you looked at heat pump water heaters? I have one and it's extremely efficient on power.The electric ones I looked at want 60A at 240VAC. I suppose that it would actually save power over a standard heater depending on frequency of use, but that seems like a very high demand.
Been there done that. Among other things, we also don't miss the open air outhouse when it's below freezing, nighttime AND the wind blowing +30 mph. Now living in a 5th wheel on all electric while we build...going to do another winter in it but this time with 5.460kw vs last year's 400w. Should be better...You only say that because you're not here taking cold showers.![]()
Hope for a lot of sunny days.Been there done that. Among other things, we also don't miss the open air outhouse when it's below freezing, nighttime AND the wind blowing +30 mph. Now living in a 5th wheel on all electric while we build...going to do another winter in it but this time with 5.460kw vs last year's 400w. Should be better...
I looked into those a while back and it really depends on the location. For my old place when you combine the low cost of power and the winter temperatures, the warranty would expire a couple years before it paid for itself. Out here at the cabin it's so cold for so long and the place spends so much time unattended that it would rot out its tank and anode before it broke even.Have you looked at heat pump water heaters? I have one and it's extremely efficient on power.
I converted to a tankless, propane and uses 120v. It takes a while before water gets hot but when it does you never run out of hot water. It saves me from keeping the water hot when I don't need it and I notice the savings. It don't use much propane to even notice.I looked into those a while back and it really depends on the location. For my old place when you combine the low cost of power and the winter temperatures, the warranty would expire a couple years before it paid for itself. Out here at the cabin it's so cold for so long and the place spends so much time unattended that it would rot out its tank and anode before it broke even.
Plus, they still require 240v and I only have a 3Kw 120v inverter.
Because it only heats the water that is used.Why would an electric instant water heater save power over a tank-type electric resistance water heater?
I agree if it is an all electric model.Because it only heats the water that is used.
Instead of constantly keeping a tank warm.
But, it's not good for off grid. Because of the high instantaneous load.
Yea like 36kw by itself. They are a huge load.Because it only heats the water that is used.
My propane OD with preheat tank uses pennies per shower. A 30# tank lasts me 3 months in summer and that is for cooking and OD water heater.My gas bill is about $8/month, for a water heater and the stove. To me, any losses are trivial, don't justify changes to save energy.
But gas is cheap, and off grid PV has a different budget.
Well, if you can't get a propane tank, I would not bother with the electric tankless. You probably better keep the tank style and put a timer on it. A normal ele., water heater tank usually takes a 30amp breaker where as a electric tankless may need a 60 amp but for a propane tankless, you only use may be 15 or 20 amp. It's plane as day. Being off grid requires you to think of ways to conserve.Yea like 36kw by itself. They are a huge load.
Can’t use gas heater because we don’t have any so its a HPWH for me.
Propane is expensive and hard to get around here.Well, if you can't get a propane tank, I would not bother with the electric tankless. You probably better keep the tank style and put a timer on it. A normal ele., water heater tank usually takes a 30amp breaker where as a electric tankless may need a 60 amp but for a propane tankless, you only use may be 15 or 20 amp. It's plane as day. Being off grid requires you to think of ways to conserve.
Can you repair that system yourself and get replacement parts off the shelf if it breaks down?I have a Heat pump water heater.
I can't.Can you quantify that in kWh savings per day?
No but I also don’t have to buy propane or NG either.Can you repair that system yourself and get replacement parts off the shelf if it breaks down?
Those are factors I consider living off grid with just a small town available.
I still have my wood stove with water tank jacket and 12 volt pump if needed.I still have my AO Smith that used 4500 watts to heat water if needed.
Propane is kinda a monopoly. Several places will keep there prices the same. What I did is bought my own tank, a large tank say 500gal. Then shop around for the lowest price in the early summer months when price is the lowest. Fill it up and make it last till the next summer. I paid 1.33 this past summer which is higher than last yr. At the same time the big boys charges 1.80 gal. Usually a family owned company will give you a lower rate if you buy just from them as I have found.Propane is expensive and hard to get around here.
We had people calling empty a couple years ago and they did without for almost a month.
It’s just another thing to tie you to the system.
Uses electric and considerably less than a tank heater
I had a Takagi years ago when I had NG.
Worked ok but if you have well water with any minerals then You are flushing that thing all the time.
Last time I had Propane I was paying $2.80 a gallon.Propane is kinda a monopoly. Several places will keep there prices the same. What I did is bought my own tank, a large tank say 500gal. Then shop around for the lowest price in the early summer months when price is the lowest. Fill it up and make it last till the next summer. I paid 1.33 this past summer which is higher than last yr. At the same time the big boys charges 1.80 gal. Usually a family owned company will give you a lower rate if you buy just from them as I have found.
I do have a Takagi and with well water. Every thing is filtered twice and softened before it reaches the WH. But as with any thing if you want it to last you need to maintain it.
