Hi,
I searched a lot here and elsewhere but can't seem to find anyone in the same situation as me:
I bought a Growatt SPF 3000TL LVM-ES and a 200Ah 48V lithium battery. The battery turns on fine and shows 50% capacity remaining. It does output 49.4V.
Since I'm in the middle of the construction of the house I haven't installed solar panels yet, but I thought I could still power the inverter using what's remaining in the battery (I want to power only few lights to be able to work on the house late)
So anyway, I just connected the battery and inverter, I checked on the inverter poles that it is getting battery power at 49.4V, but the inverter does not start. No display, no light, nothing. I've found some Youtube videos with the exact same inverter (well, the 5kW version, but it's probably the same except that) and it runs on as soon as the battery is connected...any advice ?
Additional info: I asked a neighbor to provide AC power and connected it to the AC input of the inverter. In this case the inverter started which allowed me to make all the settings (especially the battery type, set to Lithium). When it was on this way it seems the battery communication works well (the capacity displayed on the LCD of the inverter is the same as on the battery).
But when I disconnect the AC input the inverter turns off after few seconds (I guess this is because of capacitors holding a charge for a while).
I'd love to hear any of your thoughts, especially from people that experience(d) the same kind of issue.
Thanks !
Thanks !
