There are a few other posts on this topic, but nothing specific to my question. There is a confusing setting on the Shine tools app for the Growatt MIN series inverter. I need to prevent export to the grid until my installation is approved. The setting in question is Export Limitation Power Ratio% (it is under System configuration - Export limitation setting).
I have Export Limitation Setting set to Enabled via RS485 (Smart meter connected) which is fine, but then under Export Limitation Power Ratio%, should it be set to 0, or 100%? It seems that if the Limitation is 0%, then it will not limit export, whereas if it is set to 100%, then it will limit all export. But I have the feeling, it is the other way around, i.e. that 0% means no export. Has anyone used this setting and know which it should be?
