Hello everyone,
I have a SPF 3000TL LVM. It was working beautifully over the summer, but shut everything down as we got into colder temps because my DIY 24V LifePo4 battery was not insulated or heated. I've now rebuilt the battery bank in a heated box. Once it was hooked back up to the inverter and turned everything on, i'm getting a Fault #19. See the video
I've checked that theres 25V+ from the battery and into the inverter. The PV array is plugged in and I did have 120VAC plugged in as well (not in video). I've reset the inverter through the 305 code.... and no avail. Help?!
