Growatt SPF 5000 ES - 3 phase parallel setup power consumptions
sollarPASS
Austria
Hi all,
Growatt SPF 5000 es 3 phase parallel setup
(3 with PV 4,5 kw each and 3 just connected to the battery
I try to optimize the Powerkonsumptions
I allready have the slaves with Standby setting
For poweroptimizations does anybody has expirience with setting 50 or alternativ suggestions to optimize the powerconsumptions of the growatts themselfs
50 AC output time (Which AC output is meant there? Inverter, Grid, Pasthru, All)
if i would limit that to lets say 05-24 would that limit only the inverter AC output solar/battery or the passthru/bypass Output too?
If you need any additional information im open for suggestions
Thanks in advance wish you all a sunny day
just for everyone that wants to know it deactivates - passthru and PV as well as battery power to the load if you limit the timerange
three phase setup ist the worst condition to choose. First of all in the three phase setup all three inverters have to be online at the same time if one of the inverters has an error or is not communicating anymore all three will reject powering the loads properly. If you are not in need of a three phase setup you can try to go with a parallel setup. In some firmware/hardware combinations you can hotplug inverters and switch those completely off.
P50 is only the output of the inverter. If this is set to off each of the inverter will at least consume 50W up to 90W from the power sources connected. Three phase setup also disables P04 power saving mode.
So if there is not a mandatory need for a three phase setup then try to find a way to go for a parallel setup. In case you need a three phase setup I recommend to change to a different inverter...
Yeah seems like it - but i cant chaneg away its an existing 3 Phase system
You have some cool videos on youtube - i like them :-)
I will update the inverters to the latest Firmware the next days and hope that will help at least with the SBU problem i have and the fan noise.
I plan on disconnecting 3 of the 6 inverters in the evening and only reconnect them in the morning or if higher loads are needed with an ATS and an arduino or raspberrryPI. If that doesnt help i will reconfigure them on the fly with the GROTT Server remotely.
What you can do is using my winter night function to switch the parallel inverters off in night time or when you are not in need of those. At least the HST inverters on each phase need to be online all the time...
I recommend changing your house to one fase if you are under 15kVA as the asymmetric load is no problem for your provider but for your inverter
Hello with a parallel installation can we make a network injection on each inverter I have the same problem
what do you exactly mean with network injection? If your question is about the CAN communication to/from the battery the answer is yes, you can use a splitter to provide both inverters with the information of the battery...
No no I’m talking about connecting each phase of the electrical network of my network provider on my 3 inverters one phase per inverter
in a parallel setup you need to use the same phase for all inverters. only in a three phase setup you connect L1, L2 and L3 to each of the inverters. there are some circuit plans in the manual and only exactly these are possible with the SPF inverters.
Hello, just know if I use only one phase, I would have an imbalance of phases on the grid of the electricity company
the grid has constantly imbalances - that's why the voltages differ between the phases. if you need 15kW of output power then go with the three phase setup. I use a 10kW system here with 2 Inverters in parallel and those may pull max40A (~9.5kW) at peaks. but that's not an issue for the provider as you are not the only consumer on that phase right? they have options to compensate the imbalance...
