solarmaker1973
Hi everyone, I need your expert opinion. I have a Growatt SPH4000 inverter: from the settings I can set the minimum SOC value (25%) while it is not possible to set the maximum SOC value and therefore it always manages to charge up to 100 %. if I wanted to stop charging the Pylontech batteries at say 90%, what should I do? I can't find it in the settings a way to stop charging at 90% in LOAD first mode (the same is instead possible while in battery first mode..)… Thank you very much!!
