Ampster
Renewable Energy Hobbyist
I was using just 48 volts not the nominal voltage of 16 cells at 3.2 volts.My calculator says $287.72 per kWh. Perhaps I forgot to carry the 3...
I set float at just above resting voltage so that during the day some of the solar will go to the batteries during the day while there is some load. For my batteries that is 3.35 volts per cell. Rebulk is at 3.25 and Absorb 3.4Anyone here with a comparable system who can help me understand where to set the float and rebulk voltages?
Many thanks, Ampster. Very useful. On my 16-cell GYLL, that would be float at 53.6v, 52v for rebulk and 54.4v for absorb. I'll tinker with these values.For my batteries that is 3.35 volts per cell. Rebulk is at 3.25 and Absorb 3.4
Hi JoeHam,Battery manual:
GYll Battery Manual 01.pdf
workdrive.zohoexternal.com
BMS software:
bms_tools_2.0.6(3).zip
As yet untested RS485 dongle that I just ordered:
Very helpful YouTube:
Here's a video that shows the BMS dongle wiring.Hi JoeHam,
Could you tell me brown and white brown what pin on rj45?
i tried kike a video but not connectedHere's a video that shows the BMS dongle wiring.
It took me a couple of tries before I got it right.
what ethernet cable you use? white brown and brown?Updating: rewired my USB-RS485 cable with CH340 adapter, and it worked: I can see the BMS and state of cells. So now I'm ready to swap out my failing lead acid bank.
Hi JoeHam,
Dear Alkafa,what ethernet cable you use? white brown and brown?
don't worry i have many converter, i will tryDear Alkafa,
You cannot make this connection with only an ethernet cable. You must have an RJ45 plug at one end and an RS485 CH340 USB dongle at the other. The dongle has only two ports, positive and negative. The USB plug goes into your laptop. Please view and understand the video from Signature Solar.
Hi David, we're sorry that you were not forwarded to tech support and provided the info you needed, this is good feedback that we take seriously.Just went to order two 24v Gyll batteries from Signature Solar. I’m not impressed with their customer service. I plan on running two of the 24v batteries in parallel so I called to ask what size cable they recommended. I have some 2 AWG cable and wanted to know if that would work. The guy I talked to had no idea. Suggested I go to Lowe’s or Home Depot and ask someone there!
I want to add that I’m not saying these batteries are bad, I’m still interested in them. And I’m not saying that Signature Solar is bad either. Just that I was really surprised that their technical support couldn’t help me decide what size cable to use with a product they sell.
As to your question, the MAX amperage of 2AWG (assuming 90C rating) is 138A, both batteries can put out 100A, so parallel Amps could potentially be up to 200 if you used a 2/0 Wire, but if you are planning to use low amps I don't see why you would have an issue practically. Codes would say that you should match wires to amperage to keep things safe under any circumstances.
I appreciate a direct response from SignatureSolar to my issue. Thanks for that information, I will do some research and will buy cables that match the amount of possible current that two of those batteries in parallel can draw. Thanks.Hi David, we're sorry that you were not forwarded to tech support and provided the info you needed, this is good feedback that we take seriously.
