roaming ram
- Jul 24, 2022
- 36
i am a complete idiot, wired my cheap chinese isolator wrong and shorted the battery. does anyone know if a chin LiFePo4 can be reset ? thanks
yes, i put my solar panels on for it. i read in the owners manual the bms will reset if the power is completely drained so i am running my fridge without any charging for the time being. i sent an email to chin too. waiting for a response. thank you !That's why they have short circuit protection.
Have you applied a voltage source to it, like a 12V charger (may not work), 12V power supply, or put it in parallel with another 12V?
well, i can tell you the proper way to isolate your battery from your system is to use a shunt on the negative side and a positive only isolator switch on the positive side. i bought a cheap switch with no directions and only a + - sticker on it. never again.Hi roaming ram,
Sorry to hear about the battery issue. However, I was wondering if you could share the details of the isolator switch and how it failed.
Perhaps save some of us who also have the tendency from having to learn the hard way too.
Thanks
fair enough, but i have never needed or used an isolator switch before. if it says + and - i assume i should hook them both up. now i am educatedEven expensive ones may have no documentation and a certain basic level of knowledge is expected. I have 3 blue sea systems cut off switches that each cost around $50, and none came with instructions.
not the case. 400 and they send a new one to me but with scratchesGood news is this shouldn't cost you anything. Short circuit protection is standard and shouldn't ruin a BMS/battery if functioning properly.
