SCClockDr
An ATX power supply from a retired PC. Search youtube for an endless supply of videos on how to. There is a 3.3 volt rail with lots of amps.
Is it a bad idea to connect 3 cells in series and first put 6V to them, then 8V, I could do that, or connect 2 in series and charge as 4V then step to 6V. By then the LiPo setting should work and I could charge all 16 in series with the BMS connected at up to 50A. The limitation of 5A is only in the PB setting.
Use the 12 volt rail to charge the 4 in series once you are assured you've got them back. Employ a boost buck CC CV DC>DC converter off the 12 volt rail to provide an adjustable charger for experimentation/recovery.Normally I'd say no problem. But we are still not 100% sure if all these cells will take a charge, and if one doesn't the rest in series will get overcharged. But if doing it in small steps like you say, and you are careful and closely monitor each cell once in a while, go ahead.
@SCClockDr 's 3.3v ATX rail is a good idea for more amperage, and you could also use the 5v rail for two cells in series.
The main problem with using ATX type supply is that it's not capable of constant current limiting, so if the load is high enough the PSU will just shut down and be useless. So length/gauge/resistance of cables from PSU to cell terminals becomes a current limiting factor, so you have to pay attention to that and tweak it if necessary.My son has an ATX power supply, not sure, he needs to check on a resistor for the 5V post. I think I will try this method.
Bad batteries normally smell off as well.When bad things go wrong, does it mean things are all right?
Sorry, just busting your chops, no offense.
Totally agree not to leave the charge unattended when suspecting a bad outcome.
I'd use an adjustable buck converter tied to the 5v rail. That allows you to set the voltage as you desire.I've been charging at the 2V PB setting so far, but it is very slow. Seems hard to get the voltage over 1.8. Tomorrow I have time, I will try setting up the ATX power supply. I bought some variable resistors (2@100ohm variable) and 2@25 ohm) that I hope will drop the voltage enough to get the 5V post to work, if not I'll use the 3.3V and drop that voltage using the resistors to see if that works. If that fails I will try 2 cells in series on the 5V post, then experiment from there.
At this point I have 4 cells at 1.8V and they seem to hold there, the others are at the 1.6 or 1.7 from when I found the issue.
Sadly this method doesn't work on Lithium cells. You can't shock plated metallic Lithium back into the free ionsIn the old days we used to shock dead NiCad batteries (1.2v cell) with about 12 volts (limit current to about 10 amps).
I know the chemistries are totally different but seeing that it seems your cells are toast , maybe it will work.
Good luck.
