Maple Dave
- Nov 24, 2019
- 12
I bought 16 cells, Sinopoly 100AH prismatic cells. They all read 3.30V when new last fall. I drew them down to 3.0V and then connected all in parallel to bottom balance them. Then I connected them to my system, 1480 watts solar, a XW 6048 inverter, an SCP (system control panel) and a XW 60-mppt CC. The battery bank is located in a cold environment, so after watching a video by will about using a 12V heating pad and since my battery bank is 48V (actually 50-53V) I got a 48 to 12V DC converter to power the heat pad.
This battery bank is used for 1 thing only, to run a 120V emergency back up heat. Back-up because the main heat in the very small room protecting expensive equipment is a propane wall furnace which needs no power to run. The battery bank is in an insulated battery compartment. (If the emergency heat is ever needed it runs for 6 minutes/hr if the outside temp is 0 degrees F and I have a generator to recharge the battery bank if needed).
The story, my grid power never went out nor did the propane furnace fail. This inverter is grid tied, (as is a second array, 4840 watts grid tie only).
The panels got covered with snow for 3 days. During that time the air temps were in the 20's and low 30's F. It seems just the heating pad drew the battery bank down to low temp shut off (49V) and that shut off the inverter and charge controller. Result, the 16 cells now set in my living rood to see if they can be saved. They read 1.6 V and 1.7V because that 65 watt heat pad kept drawing them down with no charging possible because the SCP had shut everything down.
I bought a 120V charger, balancer (Tenergy model TB6B) which is designed to charge from 1 to 6 prismatic cells. I had planned to use that, but the manual says not to use it if the cells are under 3.3v.
Are these savable or are they garbage because of the voltage they are down to.
Advice please.
Advice please.
