Spanish Flyer
Purchased two months ago to add some storage to my 6 x US3000C battery bank; it was a bit complicated to get it to work together with the other batteries, but in the end almost everything was fine (I say everything because there was a delay on the charging process, being the US5000 the last to fully charge).
After about a month I got the dreaded red led on constant on this battery, so after trying to recover it the best way I could think of, I contacted Pylontech in China and they sent me a file with the latest update of its firmware.
Prior to trying to flash the new firmware, the battery still had one green led flashing every 3 seconds (the one that shows the standby condition of the unit).
Using the latest BatteryView version 3.0.28 and the *.bin file I received from Pylontech I attempted to flash the new version (having the US5000 alone with no other connection but the modified USB-RS485 cable)... It got up to 85% completion and then failed to accomplish the goal.
I had previously sent the "Event" file to Pylontech and they informed me that the battery had been overcharged at some stage, so my warranty was void!!
Can't understand why this happened since it had been working with the other 6 US3000C's and they are all fine (top charging voltage 52.5 V).
Anyway after the attempted Flash, the battery was completely dead; no more green flashing led and voltage across the terminals 0.0 V. BatteryView is no longer able to access the battery data....
Taking the matter into my own hands, and knowing that my warranty had gone out the window, I removed the battery from the rest of the stack, turned it upsidedown and removed the first small cover; all the BMS and wiring looked perfect with no burnt smell or anything that could show any physical damage there... I then proceeded to remove the other cover, the one that holds all the battery cells, but after making sure I had left no screws in place, here is where I could not continue with my inspection, since this main cover seems to be glued to the main battery body; the sides do lift slightly, but the center will not give way.
My first goal was to charge cell by cell with my lab adjustable 5A charger, but don't want to force this last cover.
So my MOST IMPORTANT question is: Has anyone faced this same problem with the cover? Is it glued or just melted due to overheat when overcharged?
I don't want to continue till someone knows about this problem.
Besides of that, I now have the added issue of trying to re-flash the battery,... what a disaster : (
