atatistcheff
- Sep 20, 2019
- 176
I recently noticed that a 4s battery I built with 8 Headway cells was not performing near capacity. I disassembled and found that one cell was about a volt low after the pack had fully charged. I built it using a Daly 60A BMS from eBay. I suspect that the answer is replacing the bad cell but I'm wondering if there is any way to test the BMS balance function? I know that if the cell is bad the balance function can't fix it but I'd like to have some confidence that the balancing is working.
