Solar Guppy
Red Cobra Guppy
Doubtful. It's fine on battery and grid power. Just does not like mppt. I changed the solar priority to power the load first and than charge battery. I don't think it matters much but who knows. I think I might have to return it and get something else. I should not have to fix a perfectly working heat pump.
I understand your feelings, but the reality is that a 6kw inverter is in no way enough wattage to power any home that keeps large whole home heat pumps on the critical load panel.
You can power them, but you are going to need more batteries to prevent sags, more solar ( I have 11kw ) solar and likely an inverter based heat-pump.
I replaced my York heat pump with a ducted 2-3 ton mini-split ( MrCool ) but I don't have a well pump to deal with either. Look at it this way, you have a 200 amp main?? and an inverter that is rated for 30 amps expected to power the home? ( guess based on your grid comments in the thread )
