HolaNewMexicoSunRider
Hola from the New Mexican High Desert, where Geronimo once Roamed & Billy the KID both Regulated and Renegaded (literally
ANYWAY, so I have 18 x 250watt 37.6v/8.85amp panels feeding a 24v system, via 2 150v/100amp/2500watt Tracer 10415AN EPever Solar Charge Controller(s)!.. Right... Sooooo.. to satify the 5,000watts of power, I've divided the panels into, 2 sets of 3 Panels each that are Daisy Chained (that's connected in SERIES for those who don't speak Redneck..LOL) together, at (appoxly) 112v/26.55amps...to a set of BUS BARS which PARALLELs each of the 3 incoming Neg & Pos lines, which feed into each of my (2) aforementioned EPever Tracer 10415AN charge controller(s).. Right...?!? Okay.. all is going well, and the battery bank, is charging as expected, and normally.. I run on FLOAT at between 28-30.1v (before load) daily..
BUTTTTT.. when I scroll thru the Charge Controller(s)... which SHOULD read a PV input of (appoxly) 112v & 26.5(ish)amps.. It instead is reading (appoxly/fluxing) 66-70v & 20amps!!! WTF?!?! Could this be,
A) what the Charge Controller is ONLY letting thru as part of it's "Control of Charge???"
B) a programming issue that I've failed to program (in other words.. its on factory setting, and I need to go in and tap/scroll my way thru the menu to set higher parameters??
b2)and if so.. HOW da' Fxcks do I accomplish that??!?!? lol.. (Definitely need some "hand holding" to walk me thru that monkey maze..
or..
C)... ????? (shrug..) Y'all Tell ME!! 'cause, EPever.. (of course) doesn't have a US Base(d) contact for Customer/Tech Support...! (and don't EVEN .. get me started on .. AMAZON's "pass the buck".. policy.. lol)
OHHH.. (shrug).. just to add a smig more info.. my battery bank (running on only 1 Charge Controller (9 panels/3 strings... each) is reading
44-45amps/28-30v & a load of 117v
OHHH OHH.. ALSO.. it shows.. "136kwh"... What's taht all 'bout?!?
OHHHHHH.. and just ONE MORE piece of the pie....there's this "2n" on one of the screens.. WTF.. is that??! and could that be option "D".. as the issue?!?
AlllRighty.. Amigos.. tis' ol' Redneck, could truly use sum.. extra Smarts.. to Reckon this Puzzle out!
Standing bye,
STERLING-SCOTT
P.s. just fyi.. I have 24x6v deep cycle Interstate batteries, which are configured into 6 sets of 4 Daisy Chained (seires'd) batteries (creating 6 x 24v batteries) that are then PARALLELED together and fed into (currently ) a VEVOR 3000k cont' Pure Sine Wave 24v/110-115v DC-AC Inverter. If that helps with the quandary, I am currently tussl'n with!
![Cowboy hat face :cowboy: 🤠](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f920.png)
or..
Standing bye,
STERLING-SCOTT
